So I have the autofocus working pretty darn good with the LRGB filters. Nice V pattern with good results.
But when it gets to the Ha filter is loses it ! V curve? Pffft looks more like a W or sideways Z attached to a W. AF ends up choosing whichever point was the lowest which works fairly well but still…
I tried taking longer exposures for the Ha filter and it helped a little but it still has the odd pattern.
Do I need to figure out an offset for this filter or something?
Yes, offset with Lum filter would likely be best unless you want very long exposures. You can go about setting up an offset different ways.
If you have a Bahtinov mask you can use that to determine the focus positions or you can use the Auto Focus within SGP, but you’ll likely need to use very long exposures (probably around a minute or more) to get enough data to achieve accurate focus.
I do as Jared mentions - I use the GoldFocus mask, which is extremely accurate and set up offsets for all my filters in the equipment profile filter dialog. I always focus with lum and then do an offset. (I enable backlash compensatino for my focuser too).
Agree with the offsets.
I use a Bahtinov to focus Lum and then RGB and NB filters. Did this when I first began using SGPro.
I’ve gone back a couple of times to see if things may have drifted, but no offset changes were needed.
So basically I use the Lum filter as a ‘base line’ then focus each filter and jot down the numbers the focuser displays, do the simple math and use the results as my offset numbers?
What about temperature offsets how does that come into play?
Yes, essentially focus for each filter and put the focus position in the Filter List (Define Filter List on the Filterwheel Control Panel):
These will get applied when you have “Auto adjust focus per filter” checked on the Focuser Control Panel and whenever you change between the filters the positions will get transformed into offsets.
There shouldn’t be a temperature offset between different filters. Essentially if your offsets are correct you should be able to focus with Lum, then switch back to another filter, apply the offset and be back in focus on that filter.
You can setup the auto focus to use a single filter (Specified in the Auto Focus Options window “Auto focus with filter:”). Or you can specify which filter to use for each individual filter as in the window above (which is useful if you have LRGB HA SII OIII and want to focus LRGB through the actual filter and only use L to focus the narrowband filters)
Especially that part, I was wondering about that.
I will have to try to get this set up if it ever clears again, maybe next year
