Automating dark frame acquisition
Is it possible to set up a set of darks to be taken at different times, and different temperatures?
-Jim
Also include different gains and binning. Interested in this as well.
Well… mostly, but it depends on the level of automation you are after. A bunch of dark or bias images is just a sequence like any other set of images you want to capture. You can make a sequence for it and run it whenever you’d like… specify temperatures, gain, whatever you’d like. SGPro does not have a feature where this type of sequence is generated automatically and run though. We are about to release AutoFlats which implements dynamic sequence generation for flat frames.
