I saw a post from 2015 about this same subject but there wasn’t a reply. I have the same issue all of a sudden after reloading SGP onto a new mini computer on the mount. All other aspects of the display on the mini are well within parameters and clean crisp views are present even on PHD2 looping so it cannot be a computer setting. With autostretch ticked, i get a blown out image from either focus routines, image downloads, plate solve, etcetera. I try to adjust the sliders but cannot get a fine enough movement to lock in the desired stretch. Right clicking on the image that way, is also blown out and not worth anything depending on which autostretch I select. If i remove autostretch tick mark and attempt to Lock the settings, it doesn’t hold. I tried updates and verified I am on the most recent update available. Do I have a setting somewhere not correctly ticked?
It could just be that the amount of data is so small that there isn’t much to stretch. If you can post a FITs we can check it out.
