Avalon Linear StarGo Meridian flip
François Janssen
I have an Avalon Linear with Stargo version 6.2.0. SP6. For control I use SGP.
The problem is I can’t do a auto meridian flip. I’ve used previous versions of StarGo, even the latest (version 7), but it doesn’t work.
Is there anyone with the same setup who can do that?
Hi François;
This is a known bug in that version of the driver. You need to update to the v7 driver. If that driver gives you an issue with a dialogue box popping up on slew and centre, Sefano posted this link for a fix: www.dropbox.com/s/mhzh66plkcgnfmc/Avalon…NET%20Setup.exe?dl=0
Here’s the forum thread: SGP & V 7.0 Drivers - slew and center Dialogue box problem. - Avalon Instruments Official Forum (avalon-instruments.com)
I should also add that it is necessary to update the firmware when you go to V7
Thanks Ryan
I will try
I have installed the V7 and a firmware update.
But still no flip.
