Beta 258 sequence restart - guider not playing ball
@Ken
for info, with this beta, PHD2 is not reconnecting/restarting with a sequence automatic restart. I will post log files shortly.
restart occurs around 22:00:
after I noticed it wasn’t firing up PHD2 again, and it went into recovery. I manually connected PHD2 and restarted the guider but I could not get SGP to pick up by hitting ‘retry’. I aborted the sequence and restarted and SGP picked up again. I had the ‘disconnect PHD2 on sequence end’ option enabled in SGP guider control panel - so I have disabled it now and will see if this is part of the confusion.
@buzz
It looks like SGPro did send the proper message to PHD2 to restart, but we have not taken into account guider reconnect. I’ll take a look.
[09/26/19 22:03:39.275][DEBUG] [PHD2 Listener Thread] Error received from RPC: all equipment must be connected first
@buzz
Next beta will have 2 changes… you should only need the first, but the second may come in handy in other scenarios:
  1. Disconnect auto guider will not disconnect on restart after unsafe
  2. If the guider gear does get disconnected, resume guiding will now attempt to auto-connect it
Many thanks Ken. I had another short unsafe condition (2:10-2:30) and, with the ‘disconnect PHD2@’ option disabled and the warm camera on sequence end disabled, SGP restarted successfully on its own. I’ll send an updated log anyway when its done for the night.
