Hi guys,
I had two targets loaded last night. The first one had an end time of 4:10am and the second 6:20am. SGP imaged until the first time limit was reached then it failed to start the second target. I have copied the relevant section of log file below. I have also attached a screenshot of the setup of the second target.
Does anything jump at you as being wrong? In the log file, it looks like target Sh2-274 is primed to start but then nothing happens.
thanks,
Luca
[11/30/19 04:08:51.134][DEBUG] [Sequence Thread] Target past specified end time, moving to next target…
[11/30/19 04:08:51.134][DEBUG] [Sequence Thread] Run event requested sequence break due to time limit, moving to next target…
[11/30/19 04:08:51.134][DEBUG] [Main Thread] PopulateDataModel: Transferring view to the data model…
[11/30/19 04:08:51.164][DEBUG] [Main Thread] Adding sequence level notification: Target terminated early due to target end time constraint…
[11/30/19 04:08:51.169][DEBUG] [Sequence Thread] Sending Notification: Status - Target terminated early due to target end time constraint…
[11/30/19 04:08:51.277][DEBUG] [Sequence Thread] Attempting to move to next event…
[11/30/19 04:08:51.277][DEBUG] [Sequence Thread] Finding first active group…
[11/30/19 04:08:51.277][DEBUG] [Sequence Thread] Looking at target IC 1805…
[11/30/19 04:08:51.277][DEBUG] [Sequence Thread] Target is active: True
[11/30/19 04:08:51.277][DEBUG] [Sequence Thread] Target is complete: False
[11/30/19 04:08:51.277][DEBUG] [Sequence Thread] Target marked as past end time: True
[11/30/19 04:08:51.277][DEBUG] [Sequence Thread] Target has end time: True
[11/30/19 04:08:51.277][DEBUG] [Sequence Thread] Target end time: 11/30/2019 4:10:00 AM
[11/30/19 04:08:51.277][DEBUG] [Sequence Thread] Looking at target Sh2-274…
[11/30/19 04:08:51.277][DEBUG] [Sequence Thread] Target marked as past end time: False
[11/30/19 04:08:51.277][DEBUG] [Sequence Thread] Target end time: 11/29/2019 6:20:00 AM
[11/30/19 04:08:51.277][DEBUG] [Sequence Thread] Looking at target M1…
[11/30/19 04:08:51.277][DEBUG] [Sequence Thread] Target is active: False
[11/30/19 04:08:51.277][DEBUG] [Sequence Thread] Target end time: 10/22/2019 6:00:00 AM
[11/30/19 04:08:51.277][DEBUG] [Sequence Thread] Looking at target Flat…
[11/30/19 04:08:51.277][DEBUG] [Sequence Thread] Target has end time: False
[11/30/19 04:08:51.277][DEBUG] [Sequence Thread] Target end time: 12/8/2018 4:59:00 PM
[11/30/19 04:08:51.277][DEBUG] [Sequence Thread] Looking at target NGC 7335…
[11/30/19 04:08:51.277][DEBUG] [Sequence Thread] Target end time: 10/22/2019 4:30:00 AM
[11/30/19 04:08:51.277][DEBUG] [Sequence Thread] Looking at target NGC 5985…
[11/30/19 04:08:51.277][DEBUG] [Sequence Thread] Target end time: 10/22/2019 4:15:00 AM
[11/30/19 04:08:51.277][DEBUG] [Sequence Thread] Looking at target NGC 2359…
[11/30/19 04:08:51.277][DEBUG] [Sequence Thread] Target end time: 10/22/2019 3:30:00 AM
[11/30/19 04:08:51.277][DEBUG] [Sequence Thread] Looking at target IC 405…
[11/30/19 04:08:51.277][DEBUG] [Sequence Thread] Target end time: 10/22/2019 3:00:00 AM
[11/30/19 04:08:51.277][DEBUG] [Sequence Thread] Looking at target B 33…
[11/30/19 04:08:51.277][DEBUG] [Sequence Thread] Target end time: 10/21/2019 10:00:00 PM
[11/30/19 04:08:51.277][DEBUG] [Sequence Thread] Looking at target IC 410…
[11/30/19 04:08:51.277][DEBUG] [Sequence Thread] Sequence complete.
[11/30/19 04:08:51.277][DEBUG] [Sequence Thread] No valid targets remain, aborting…
[11/30/19 04:08:51.278][DEBUG] [Sequence Thread] ********* Run post sequence *********
[11/30/19 04:08:51.278][DEBUG] [Sequence Thread] SGPro capture cal frame mode is OFF…
[11/30/19 04:08:51.278][DEBUG] [Sequence Thread] Capture calibration frames on sequence failure is active. Abort status: False; User Abort: True
[11/30/19 04:08:51.278][DEBUG] [Sequence Thread] Turning capture cal frame mode OFF (because sequence was aborted by user) or no calibration frames exist.
[11/30/19 04:08:51.280][DEBUG] [Sequence Thread] Clearing timed monitoring events…
[11/30/19 04:08:51.280][DEBUG] [Sequence Thread] Checking RunEndOfSequenceEquipmentOptions, force = True
[11/30/19 04:08:51.280][DEBUG] [Sequence Thread] In RunEndOfSequenceEquipmentOptions
[11/30/19 04:08:52.267][DEBUG] [Image History Worker] Star detection using min star size of 2px…
[11/30/19 04:08:52.267][DEBUG] [Image History Worker] Star detection using max star size of 40px…
[11/30/19 04:08:52.311][DEBUG] [Image History Worker] Find stars took: 1801 ms…
[11/30/19 04:08:52.311][DEBUG] [Image History Worker] Star list contains 197 stars…
[11/30/19 04:08:52.311][DEBUG] [Image History Worker] Calculating HFR with sample size: 4
[11/30/19 04:08:52.391][DEBUG] [Image History Worker] Image analysis (async) END
[11/30/19 04:09:22.259][DEBUG] [Main Thread] Adding sequence level notification: Warming the CCD…
[11/30/19 04:09:22.265][DEBUG] [Sequence Thread] Sending Notification: Status - Warming the CCD…
[11/30/19 04:09:22.265][DEBUG] [Main Thread] Adding sequence level notification: Auto guider has been stopped successfully.
[11/30/19 04:09:22.268][DEBUG] [TEC Thread] SGM_CHANGE_COOLER_TEMP message received…
[11/30/19 04:09:22.268][DEBUG] [TEC Thread] TEC Change: Starting…
