Binning exposure
Regardless of binning setting I get the same exposure (average ADU). Noticeable when using the Flats wizard. Regardless of binning I get the same exposure time for the same average ADU. Only the image size (width x height) changes. I’m using a ZWO ASI1600MM camera.
Why is this? Using SGPro 2.6.0.24.
If I use Sharcap both exposure and size change with binning. I believe that is the correct behavior.
I’m not sure. But, I seem to recall it working some time ago. Is it a version change issue?
Nobody has any idea?
I don’t have this hardware so can’t test but if the camera is giving the same average ADU value for different bin values then I think you can expect that the flat exposure time will not change because the reason for changing the exposure is to change the ADU value.
As you say binning can be expected to increase the ADU value, by 4 times for 2x2 binning. If it isn’t this may be something you need to raise with the camera manufacturer. They could be reading one pixel in each 2x2 block rather then summing all 4.
