After this “fix” was introduced temperature compensation is completely broken for me, it moves away from focus because it doesn’t care about auto focus being run, it only cares about the original focus position at the start of the run which might be totally wrong (since that position is from the night before at a different temperature)
The same settings has been used for 4-5 months with very good focus/temperature compensation before upgrading to 3.0.10 lately.
Name for a few confimed good frames right after autofocus (rest are crap as can be seen from the screenshots)
M13_Light_Lum_600sec_2018-04-19_frame3.fit
M13_Light_Green_300sec_2018-04-19_frame5.fit
M13_Light_Blue_300sec_2018-04-19_frame9
Attached is screenshots of image history and the logfile.
Auofocus at frame3 here, as can be seen for frame 4 it looks like temp comp totally ignores that an autofocus has been made and moves to a position in relation to the original position
I’m really suprised this problem has been there for almost 2 months without a fix being made, also there’s no older v3 to download on the website to go back to an older version
Thankfully i had the 3.0.0.7 installer so i can use that version till a fix is made for the newest version.
Looking at this now. Updating the Temp and Position should be pretty easy when Auto Focus is ran. I’m trying to think through any other cases where updating these values may be needed.
Here is a almost completely untested build. Use at your own risk and be sure to backup your existing installation. If you have any issues (or if you have no problems) let me know.
Also don’t be to surprised if this completely fails to work or even install. This is off of our new build server and we haven’t been able to 100% test a build off of it yet (but they’ve been looking pretty good)
No worries. This happened locally as well and I’m not entirely sure what’s causing it. Something probably isn’t getting put into place by the install. Yay, new build fun :-/
