cmassa
November 23, 2019, 3:06am
1
I get this every time I start build 383. If I continue it, SGP doesn’t auto load the sequence. When I quit SGP it throws the same error. I went back to build 375 which starts up fine.
Chris
cmassa
November 23, 2019, 3:29pm
2
I tried it again this morning and get the same error. I found that if I hit continue in the error box, SGP opens in a small window and the splash screen stays open as well and says it is opening last sequence.
Chris
Ken
November 23, 2019, 5:30pm
3
Could you please send the sequence and full text of that exception above?
Heno
November 23, 2019, 6:01pm
4
I experience the same problem.
I just tried and startup is fine. Shut down gives the following popup with c
“Continue” doing nothing and “Quit” closing SGPro. The full text of issue is below the image :
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at sh.afv()
at sh.p2(String A_0, Boolean A_1)
at sh.ai0()
at SequenceGenerator.MDIImageForm.a(Object A_0, FormClosingEventArgs A_1)
at System.Windows.Forms.Form.OnFormClosing(FormClosingEventArgs e)
at System.Windows.Forms.Form.WmClose(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.8.4070.0 built by: NET48REL1
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
Sequence Generator
Assembly Version: 3.1.0.383
Win32 Version: 3.1.0.383
CodeBase: file:///C:/Program%20Files%20(x86)/Sequence%20Generator/Sequence%20Generator.exe
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
ServiceStack
Assembly Version: 3.9.48.0
Win32 Version: 3.9.48.0
CodeBase: file:///C:/Program%20Files%20(x86)/Sequence%20Generator/ServiceStack.DLL
ServiceStack.Interfaces
CodeBase: file:///C:/Program%20Files%20(x86)/Sequence%20Generator/ServiceStack.Interfaces.DLL
ASCOM.Utilities
Assembly Version: 6.0.0.0
Win32 Version: 6.4.1.2695
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/ASCOM.Utilities/6.0.0.0__565de7938946fba7/ASCOM.Utilities.dll
ASCOM.Astrometry
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/ASCOM.Astrometry/6.0.0.0__565de7938946fba7/ASCOM.Astrometry.dll
Microsoft.VisualBasic
Assembly Version: 10.0.0.0
Win32 Version: 14.8.4070.0 built by: NET48REL1
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System.Core
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
Newtonsoft.Json
Assembly Version: 12.0.0.0
Win32 Version: 12.0.2.23222
CodeBase: file:///C:/Program%20Files%20(x86)/Sequence%20Generator/Newtonsoft.Json.DLL
System.Numerics
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll
System.Runtime.Serialization
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Serialization/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll
System.Data
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
System.Xml
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
System.Configuration
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
Accessibility
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
RestSharp
Assembly Version: 100.0.0.0
Win32 Version: 105.2.3.0
CodeBase: file:///C:/Program%20Files%20(x86)/Sequence%20Generator/RestSharp.DLL
Anonymously Hosted DynamicMethods Assembly
Assembly Version: 0.0.0.0
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/mscorlib/v4.0_4.0.0.0__b77a5c561934e089/mscorlib.dll
ServiceStack.ServiceInterface
CodeBase: file:///C:/Program%20Files%20(x86)/Sequence%20Generator/ServiceStack.ServiceInterface.DLL
ServiceStack.Common
CodeBase: file:///C:/Program%20Files%20(x86)/Sequence%20Generator/ServiceStack.Common.DLL
ServiceStack.Text
Assembly Version: 3.9.45.0
Win32 Version: 3.9.45.0
CodeBase: file:///C:/Program%20Files%20(x86)/Sequence%20Generator/ServiceStack.Text.DLL
System.Web
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/System.Web/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Web.dll
ASCOM.DeviceInterfaces
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/ASCOM.DeviceInterfaces/6.0.0.0__565de7938946fba7/ASCOM.DeviceInterfaces.dll
GraphLib
Assembly Version: 1.0.0.1
Win32 Version: 1.0.0.1
CodeBase: file:///C:/Program%20Files%20(x86)/Sequence%20Generator/GraphLib.DLL
QuadraticFocus
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/Sequence%20Generator/QuadraticFocus.DLL
MediaSlider
Assembly Version: 1.3.0.0
Win32 Version: 1.3.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/Sequence%20Generator/MediaSlider.DLL
netstandard
Assembly Version: 2.0.0.0
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/netstandard/v4.0_2.0.0.0__cc7b13ffcd2ddd51/netstandard.dll
System.Data.Linq
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Data.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Data.Linq.dll
System.Xml.Linq
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.Linq.dll
BetterListViewExpress
Assembly Version: 3.15.0.0
Win32 Version: 3.15.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/Sequence%20Generator/BetterListViewExpress.DLL
CodeBase: file:///C:/Program%20Files%20(x86)/Sequence%20Generator/BetterListViewExpress.dll
System.Windows.Forms.DataVisualization
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms.DataVisualization/v4.0_4.0.0.0__31bf3856ad364e35/System.Windows.Forms.DataVisualization.dll
System.Management
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Management/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Management.dll
ASCOM.DriverAccess
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/ASCOM.DriverAccess/6.0.0.0__565de7938946fba7/ASCOM.DriverAccess.dll
Microsoft.WindowsAPICodePack.Shell
Assembly Version: 1.1.0.0
Win32 Version: 1.1.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/Sequence%20Generator/Microsoft.WindowsAPICodePack.Shell.DLL
CodeBase: file:///C:/Program%20Files%20(x86)/Sequence%20Generator/Microsoft.WindowsAPICodePack.DLL
WindowsBase
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
And I don’t believe it is sequence related as it gives the same issue when closing with just the default sequence loaded. So literally open SGPro and close right away without changing a thing causes the error. I also did a comparison between the error when loading a sequence and not loading up a sequence and the error details are identical.
Hope this helps…
dnube
November 24, 2019, 2:38am
7
I’m getting same thing as @cmassa when starting and closing build 383. Rolled back to 375 and all is ok.
DaveNL
Rakla
November 24, 2019, 8:14am
8
In my case I only get the exception on exit, but not startup.
/Ralf
It works ok for me, opens and closes with no problem.
Pleased to say the Version 3.1.0.387 now opens and closes without issue…
