Not sure if this is a bug or feature request. I’ve had some issues recently with auto meridian flip failures. The sequence ended without completing the calibration (flats) events. Is this expected behaviour?
The auto meridian flip failure resulted because of either “FlipWait: ending wait due to telescope parked or not tracking…” or “ASCOM Telescope: Failed to flip because starting pier side and ending pier side are the same!”.
Also interestingly, the message at bottom of SGP window is “Sequence Aborted (User aborted meridian flip)” even though “user” was asleep at the time :=)
That is not the setting I refer to (related, but not, in fact the actual setting). What you are showing are values that new sequences are created with. It means that this setting is probably on, but you’d need to check the actual setting for the sequence (see link I sent). If that setting is enabled for the sequence, we’d need to see logs.
It looks like an issue crept in where calibration mode is trying to restart the auto guider and failing (obviously). I have that fixed in the next 4.0 beta (not released yet).
