I have used the calibration wizard for years to add events to an existing sequence for Flats, Dark Flats and Darks.
Never had an issue until a few months ago after installing an update after which the sequence runs one image from each event and cycles through the events rather than run all images in an event before moving to the next event.
So, it takes a Flat, then tells me to remove light box for a dark flat, then takes a Dark, then goes back to take the next flat.
I’m not aware of having changed any settings and the sequence settings look ok to me in that they are set to complete each event before moving to the next event - also I don’t have this problem with lights, they still run the full event before moving to the next.
I work around it by only having one event ticked at a time. Don’t know if its a bug or something I have done. I have some screen shots showing settings and the issue actually happening if you need them.
Aprox time of issue: 12/04/2020 c10:15
Link to Logs
Useful Info
OS: Microsoft Windows 10 Home
Ver: 3.1.0.457
.NET: 4.8
