Camera Angle
Inside fit file data, and when plate-solving, the angle is reported, and I am assuming the angle is the camera orientation angle? Can the angle be monitored through SGP while setting up to image?
Yes but it is realative. It is mainly intended for those whom have either an autorotator or wish to rotate it manually.
See the manual under the control panel equipment, other equipment, rotator section.
http://www.mainsequencesoftware.com/Content/SGPHelp/SequenceGeneratorPro.html?ControlPanelEquipment.html
Thanks, so the position indicated in that user interface, the 20-degrees, is that the current orientation of the camera? Will that number change if I rotate the camera manually? Does it correlate with the angle reported in plate solving or the file metadata?
