Camera warms beyond set temperature on Abort
I have been experiencing typical Louisiana weather with clouds at night. That has caused me to abort the sequence and select the “run end of sequence” option. The camera (ASI2600MC Pro) starts to warm but it continues to warm much higher than the set temperature (15C in 10min). I have to manually stop the warming process before SGPro completes the rest of the shutdown and disconnect. What am I missing in my sequence setup?
I tested this here and didn’t spot any issues so I’m not sure off hand but, if you have logs showing an instance of this, they will go a long way toward spotting the issue.
Did you see what temperature that SGPro was headed toward in the warmup?? It’s the number on the right side of the / character.
