Hello, I have feature request if you dont mind
Its advised to never run cooler at 100% power to prevent cooler damage.
Can you please add setting to allow user to control max possible TEC power which SGP will request from camera driver?
I’m using QHY camera (QHY695A) and their driver do not allow me to limit max TEC power. But they specify in manual that you should never run it at 100 to prevent its damaging.
right now there is no way to unconditionally prevent cooler to run at 100%
my problem that if I want to start cooling process manually, I dont want to use option cool down when camera connects or cool down when sequence starts, I want to turn cooler on in Camera cooler docking window. When I do this SGP immediately starts cooling at 100% power, so I have to be very quick to abort cooling and click Cool button instead. but for several seconds TEC power is 100% and temperature rapidly decreasing by 10-15 degrees in merely 1-2 seconds.
once when I turned cooler on, my remote connection to computer running telescope dropped, so cooler was at 100% for like 10-15 seconds until I reconnected. it was really scary, I would hate if something like this will eventually damage my camera.
so please consider adding such option in camera settings in equipment profile, if its ofcourse possible to do
thanks!
