SGpro 3.0.2.94 and PHD2 v2.6.5dev3
Looks like can’t get profile bugs come back again. Can someone check with it and report back?
Thanks.
Tom
Thanks.
Tom
Nobody using PHD2 with SGpro?
Hi Tom,
You must be joking …
Now for the profiles:
In SGP please go to the “Equipment Profile Manager”, select your default profile and then select the “Auto Guide” tab. Thenn go to “Settings”. Check all your entries there, especially the “PHD2 Install Path” and the “PHD2 Equipment Profiles” ( @Jared: shouldn’t that be called “PHD2 Equipment Profile” ?).
Then, after saving everything, just “Apply Profile to Sequence”.
If nothing works, you may want to upload the log file of that session.
Kind Regards,
Horia
Hi Tom,
Try ‘resetting’ (so to speak) the install directory of PhD to the same spot by just accessing it through the GUI and selecting ok.
I just had that error on a new build observatory pc. Doing that did the trick.
Sadly…done everything. Still doesn’t work. Previously works like champ.
Thanks everyone and keep testing.
This is PHD2 section from the log file.
[08/16/18 12:53:05.540][DEBUG] [PHD2 Startup Thread] Connecting to PHD2…
[08/16/18 12:53:05.547][DEBUG] [PHD2 Startup Thread] Waiting for socket connection to PHD2…
[08/16/18 12:53:05.555][DEBUG] [PHD2 Listener Thread] Attempting to connect to PHD2…
[08/16/18 12:53:06.548][DEBUG] [PHD2 Startup Thread] Waiting for socket connection to PHD2…
[08/16/18 12:53:06.557][DEBUG] [PHD2 Listener Thread] Failed to establish client connection to PHD2 using port 4400: No connection could be made because the target machine actively refused it 127.0.0.1:4400
[08/16/18 12:53:07.554][DEBUG] [PHD2 Startup Thread] Waiting for socket connection to PHD2…
[08/16/18 12:53:08.555][DEBUG] [PHD2 Startup Thread] Waiting for socket connection to PHD2…
[08/16/18 12:53:09.556][DEBUG] [PHD2 Startup Thread] Waiting for socket connection to PHD2…
[08/16/18 12:53:10.557][DEBUG] [PHD2 Startup Thread] Successfully connected to PHD2…
[08/16/18 12:53:10.559][DEBUG] [PHD2 Startup Thread] PHD2 GetPhdStatus - Pre-Wait : Stopped
[08/16/18 12:53:10.560][DEBUG] [PHD2 Startup Thread] Sending to PHD2:
{“method”: “get_app_state”, “id”: 1001}
[08/16/18 12:53:10.661][DEBUG] [PHD2 Startup Thread] PHD2 GetPhdStatus - Post-Wait: Stopped
[08/16/18 12:53:10.667][DEBUG] [PHD2 Startup Thread] PHD2: PHD2 is already open…
[08/16/18 12:53:10.668][DEBUG] [PHD2 Startup Thread] Sending to PHD2:
{“method”: “get_profiles”, “id”: 1009}
[08/16/18 12:53:19.719][DEBUG] [PHD2 Profile Thread 1] PHD2: PHD2 is already open…
[08/16/18 12:53:19.719][DEBUG] [PHD2 Profile Thread 1] Sending to PHD2:
Hope this will help.
Tom
This line is a little suspect. Seems that either a firewall issue or the PHD2 server isn’t running or SGP hasn’t been allowed access to that port (different type of firewall issue).
With netstat /an, manage to see 127.0.0.1:4400 in action.
Tested with another imaging software, no problem at all when connect to PHD2.
I already turn off my Windows 10 firewall. But still unable to retrieve profiles from PHD2.
I had the same problem yesterday evening setting up phd2 (v2.6.6) with SGP. Any solution found for this issue?
