If I manually run PlateSolve2.exe from the “C:\Program Files (x86)\Sequence Generator” folder, it solves an image fine. However, if I try to solve from SGP, it fails and falls back to blind solve. If I try to click “settings” in the plate solver settings tab, the hourglass cursor icons shows up for a second, then disappears and nothing happens. The catalogs are correctly set in parameters. As I said, solves fine manually. It seems that SGP is having trouble talking to it.
In the logs it seems to be referring to another version of PlateSolve2.exe in C:\Users\Troy\AppData\Local\SequenceGenerator but if I double click that one, hourglass cursor then nothing.
Any ideas?
[07/27/19 22:36:25.391][DEBUG] [Camera Thread] SGM_CAMERA_PLATE_SOLVER_CAPTURE complete…
[07/27/19 22:36:25.722][DEBUG] [Telescope Thread] ************* SOLVE HINTS ****************
[07/27/19 22:36:25.722][DEBUG] [Telescope Thread] SOLVER: PlateSolve2
[07/27/19 22:36:25.722][DEBUG] [Telescope Thread] BLIND: False
[07/27/19 22:36:25.722][DEBUG] [Telescope Thread] METHOD: Max Regions
[07/27/19 22:36:25.722][DEBUG] [Telescope Thread] RA: 18.0643402775106
[07/27/19 22:36:25.722][DEBUG] [Telescope Thread] DEC: -24.1628643767622
[07/27/19 22:36:25.722][DEBUG] [Telescope Thread] SCALE: 2.5550787262712
[07/27/19 22:36:25.723][DEBUG] [Telescope Thread] ******************************************
[07/27/19 22:36:25.781][DEBUG] [Telescope Thread] FitsFileHeaderData: Angle - 0
[07/27/19 22:36:25.781][DEBUG] [Telescope Thread] FitsFileHeaderData: Scale - 0
[07/27/19 22:36:25.782][DEBUG] [Telescope Thread] FitsFileHeaderData: RA - 18.0643402775105
[07/27/19 22:36:25.782][DEBUG] [Telescope Thread] FitsFileHeaderData: DEC - -24.1628643767622
[07/27/19 22:36:25.787][DEBUG] [Telescope Thread] PlateSove2 Param: RA (RAD) - 4.72923322564778
[07/27/19 22:36:25.787][DEBUG] [Telescope Thread] PlateSove2 Param: DEC (RAD) - -0.421721540087349
[07/27/19 22:36:25.787][DEBUG] [Telescope Thread] PlateSove2 Param: Width - 5634
[07/27/19 22:36:25.787][DEBUG] [Telescope Thread] PlateSove2 Param: Height - 3753
[07/27/19 22:36:25.787][DEBUG] [Telescope Thread] PlateSolve2 Command Line:
[07/27/19 22:36:25.787][DEBUG] [Telescope Thread] C:\Users\Troy\AppData\Local\SequenceGenerator\PlateSolve2.exe 4.72923322564778,-0.42172154008735,0.06979044949901,0.04648980421899,3000,C:\Users\Troy\AppData\Local\SequenceGenerator\Temp\psXSolve_0.fit
[07/27/19 22:36:32.816][DEBUG] [Telescope Thread] *********** SUCCESSFUL SOLVE *************
[07/27/19 22:36:32.816][DEBUG] [Telescope Thread] SOLVER: False
[07/27/19 22:36:32.816][DEBUG] [Telescope Thread] SUCCESS: False
[07/27/19 22:36:32.816][DEBUG] [Telescope Thread] CONF: 0
[07/27/19 22:36:32.816][DEBUG] [Telescope Thread] BLIND: False
[07/27/19 22:36:32.816][DEBUG] [Telescope Thread] RA: 0
[07/27/19 22:36:32.816][DEBUG] [Telescope Thread] DEC: 0
[07/27/19 22:36:32.816][DEBUG] [Telescope Thread] SCALE: 0
[07/27/19 22:36:32.816][DEBUG] [Telescope Thread] FLIPPED: False
[07/27/19 22:36:32.816][DEBUG] [Telescope Thread] ANGLE (EON): -500
[07/27/19 22:36:32.816][DEBUG] [Telescope Thread] MSG: PlateSolve 2 failed! No APM file found.
[07/27/19 22:36:32.816][DEBUG] [Telescope Thread] ******************************************
