Can't start a sequence without a plate solver set up
Last night I created a profile where I didn’t select a Plate Solver. My mount is more than accurate enough to center a target without the need of one.
I created a equipment profile that has no PlateSolver.
In the framing and mosaic wizard I made sure to click the bubble that tells it not to plate solve only to slew to the target.
I also unchecked the box to verify angle.
However when attempting to run the sequence it kept telling me I needed to have a plate solver.
I doubled checked my equipment proflie
I created a new sequence with that profile
I re-did the framing wizard
Verified that I didn’t have it plate solving
Still will not start sequence because I don’t have a plate solver.
How can I fix this?
The dialog should be giving you some indication of what is blocking you from starting the sequence.
Seems to have to do with doing an automated meridian flip. On the telescope tab I have “Use Auto Meridian Flip” checked and then under the “set” button/menu I have “Auto center after Meridian Flip” checked.
I have unchecked that box. I’ll try it later tonight and see if that fixed it.
