There are related topics in this forum but none with solutions.
I have had a recurring problem with my mount disconnecting or becoming unresponsive during imaging sessions with SGP. This issue used to happen constantly when I was using a different computer but seemed to go away briefly when I switched to a new one. Now it is happening again.
Thanks to a stretch of good weather, I’ve had my rig outside for the past two nights. Two nights ago, I had no problems. This morning, however, when I checked my imaging computer, I was greeted by an error message saying the Celestron mount server stopped working or responding (just after I went to bed, naturally.) I regret that I did not have the presence of mind to take a screen shot of the error.
I think the logs indicate the mount stopped responding around 12:25 AM:
[05/20/17 00:25:10.212][DEBUG] [PHD2 Listener Thread] Unknown object from PHD2: {"Event":"Alert","Timestamp":1495265110.206,"Host":"NUC","Inst":1,"Msg":"PulseGuide command to mount has failed - guiding is likely to be ineffective.","Type":"warning"}
[05/20/17 00:25:11.068][DEBUG] [PHD2 Listener Thread] Unknown object from PHD2: {"Event":"Alert","Timestamp":1495265111.034,"Host":"NUC","Inst":1,"Msg":"PulseGuide command to mount has failed - guiding is likely to be ineffective.","Type":"warning"}
[05/20/17 00:25:13.971][DEBUG] [Sequence Thread] SaveFileAscom: Done
[05/20/17 00:25:13.971][DEBUG] [Sequence Thread] =========== Save file took 23131 ms
[05/20/17 00:25:13.974][DEBUG] [Sequence Thread] Resuming auto guiding (settling)...
[05/20/17 00:25:13.974][DEBUG] [Sequence Thread] Checking PHD2 state...
[05/20/17 00:25:13.974][DEBUG] [Sequence Thread] PHD2 GetPhdStatus - Pre-Wait : Guiding
[05/20/17 00:25:13.974][DEBUG] [Sequence Thread] Sending to PHD2:
{"method": "get_app_state", "id": 1001}
[05/20/17 00:25:14.075][DEBUG] [Sequence Thread] PHD2 GetPhdStatus - Post-Wait: Guiding
[05/20/17 00:25:14.075][DEBUG] [Sequence Thread] PHD2: Requested unpause, but PHD2 reports it is not in a paused state
[05/20/17 00:25:14.075][DEBUG] [Sequence Thread] EventMarker 18 - t:M51 (1); e:0; f:14; o:
[05/20/17 00:25:14.081][DEBUG] [Sequence Thread] EventMarker 19 - t:M51 (1); e:0; f:15; o:
[05/20/17 00:25:14.081][DEBUG] [Sequence Thread] EventMarker 20 - t:M51 (1); e:0; f:15; o:
[05/20/17 00:25:14.081][DEBUG] [Sequence Thread] Running post event...
[05/20/17 00:25:14.081][DEBUG] [Sequence Thread] EventMarker 21 - t:M51 (1); e:0; f:15; o:
[05/20/17 00:25:14.082][DEBUG] [Sequence Thread] Incremented numComplete (15) for event[0]...
[05/20/17 00:25:14.083][DEBUG] [Sequence Thread] Attempting to find next event...
[05/20/17 00:25:14.083][DEBUG] [Sequence Thread] Current event[0] frame count: 15/100...
[05/20/17 00:25:14.083][DEBUG] [Sequence Thread] Current event event[0] has remaining frames. Returning current event.
[05/20/17 00:25:14.083][DEBUG] [Sequence Thread] Checking for auto manual focus (post)...
[05/20/17 00:25:14.083][DEBUG] [Main Thread] PopulateDataModel: Transferring view to the data model...
[05/20/17 00:25:14.089][DEBUG] [Sequence Thread] Attempting to move to next event...
[05/20/17 00:25:14.089][DEBUG] [Sequence Thread] Attempting to find next event...
[05/20/17 00:25:14.089][DEBUG] [Sequence Thread] Current event[0] frame count: 15/100...
[05/20/17 00:25:14.089][DEBUG] [Sequence Thread] Current event event[0] has remaining frames. Returning current event.
[05/20/17 00:25:14.089][DEBUG] [Sequence Thread] Running pre event...
[05/20/17 00:25:14.097][DEBUG] [Sequence Thread] Current target has end time at 5/20/2017 3:30:00 AM
[05/20/17 00:25:14.097][DEBUG] [Sequence Thread] End time of next frame is at 5/20/2017 12:28:14 AM
[05/20/17 00:25:14.097][DEBUG] [Sequence Thread] Target is still before end time, continuing...
[05/20/17 00:25:14.097][DEBUG] [Sequence Thread] Running capture event...
[05/20/17 00:25:14.097][DEBUG] [Sequence Thread] SetStartTemp: Using focuser for temperature...
[05/20/17 00:25:14.097][DEBUG] [Sequence Thread] Set start frame temp to 16.06...
[05/20/17 00:25:14.832][DEBUG] [PHD2 Listener Thread] Unknown object from PHD2: {"Event":"Alert","Timestamp":1495265114.796,"Host":"NUC","Inst":1,"Msg":"PulseGuide command to mount has failed - guiding is likely to be ineffective.","Type":"warning"}
[05/20/17 00:25:30.092][DEBUG] [Main Thread] PopulateDataModel: Transferring view to the data model...
[05/20/17 00:25:30.096][DEBUG] [MF Update Thread] Performing serialize...
[05/20/17 00:26:14.838][DEBUG] [PHD2 Listener Thread] PHD2 - No messages received from PHD2 for 1 minute, checking socket with status...
[05/20/17 00:26:14.838][DEBUG] [PHD2 Listener Thread] Checking PHD2 state...
[05/20/17 00:26:14.838][DEBUG] [PHD2 Listener Thread] PHD2 GetPhdStatus - Pre-Wait : Guiding
[05/20/17 00:26:14.838][DEBUG] [PHD2 Listener Thread] Sending to PHD2:
Link to logs:
logs.zip (243.4 KB)
My setup:
Celestron AVX mount running latest firmware
Intel NUC7i5BNK mini PC running fully updated Windows 10
Powered USB 3 hub
SGP 2.6.0.23
PHD2 2.6.3
ASCOM platform 6.3
latest Celestron ASCOM driver
Thanks for looking. I’d sure appreciate any help you can offer.
Glenn
