Does center here on an image with the right click require a second plate solve to change to the new coordinates. If you right click on an image and say center here it will plate solve to get to that center. Then do you have to do another plate solve and choose this for the new coordinates. I’ve tried this without the second platesolve and the image goes back to the original coordinates from frame and mosaic wizard I choose originally
Hi, I had that problem when solving using Plate Solve 2 but since changing to ASTAP I find the recentre to cursor works fine. I also get a measage asking if I want to use this plate solve for that object in the future. I’ve had no problems then on revisiting that object.
