I have not yet tried this function in SGPro
If I input a Location (J2000) in Target Settings, will SGPro understand how to move my mount (CGX) if the first image captured does not show the target.
For example:
M81’s J2000 catalog location is: RA 09h 55m 33.2s DEC +69° 3′ 55″
But, when SGPro does its first plate solve, the solved location is (example):
M81’s J2000 solved location RA 09h 53m 00.0s DEC +69° 5′ 00″
The offset between the two values would be: RA 0h 2m 33.2s DEC 0° 2’ 5"
This will likely mean M81 is not in the image with an ASI294. Will SGPro understand the offset and move the mount to re-center?
SGPro knows the scope I am using, knows the imaging camera I am using so it should understand the offset error.
