Last night I run into a weird issue. If I hit center here SGP would center on another part of the image. Plate solving with astrometry always worked great. It’s almost as if SGP tought that I clicked on another part of the image. Has anyone run into this before?
There is a known issue with center here and using astrometry.
Oh wow is there a solution?
For the time being the solution is to either not use center here or use pinpoint or Elbrus for plate solving.
This only affects center here. All other plate solves work. So you can get accurate cordinates through the framing and mosaic wizard or from other sources and not need center here.
Unfortunately pinpoint always fails with my 2000mm scope. It works fine on my other ones. I will try Elbrus.
