Dear astronomers.
Since some time ago I wonder if there is any way to choose slewing speed when It slews in automatic mode, for instance, when centering an object is running. I’m thinking about neighbours rest in night and the mount sounds a lot at these hours.
Is there any posibility in SGP?
Is this option located in EQMOD setup?
Thank you in advance
If you open up the extended options in EQMod, then in the panel that opens out, right in the centre, is a box and slider for Other Setting \ GoTo Rate Limit. Now that slider should normally be all the way to the left for unlimited slewing, but if you slide it right, it should apply a limit and slow down your slewing. Then it’s just a case of trial and error as to how long you are prepared to wait for a slew versus waking up the neighbours.
Terry
Thank you! I’ll test it tonight!
