is there an option to have SGP close the flat panel as part of running the end of sequence?
Directly, not that I’ve seen. Indirectly, I add a final target to my sequence with one event that does a 1-second dark exposure. SGP will close the flat panel for that.
Dave
it’s easy enough to add. I’ll pop it into 4.4
I just took a look at the code for that part of shutdown and, as of this moment, SGPro should be closing the flatbox shutter every time all the time at sequence end so not sure a special dark/flat event would be needed.
In any case, I have now added an explicit option to do this and, even better, for folks imaging from tight spaces, you can choose to close the flatbox shutter either before or after mount park.
thanks very much! thats awesome cheers
