Hello I’m starting with SGpro and I’d like to know if you can generate sessions for comets and asteroids
For comets, one of the methods is to cycle through a sequence of LRGB,LRGB,… with 30 second delay between exposures. In that way, when you combine the colors, the stars do not overlap and it is possible to process the stars and comet separately.
ok thank you so much as time allows
