Hello together,
I would like to ask you, if you please can provide the PinPoint time out limit property as configurable item within SGPro.
Background:
It allways happens from time to time that the plate solve fails. May be because of a bad image, may be because the hints are too way off the actual target.
A few weeks ago I made a longer plate solving testing session with Visual PinPoint and also with SGPro (with PinPoint as PlateSolver).
I found out that on my new laptop, that if the plate solving was not successful after 10-15 seconds, it doesn’t work at all (even if I push up the time out limit in Visual PinPoint to 300s).
For other laptops another time out limit may be appropriate.
For that I would be happy, if I could reduce this wasted time. For me 40 seconds staring at the plate solving progress bar (without the hope for a good outcome) is a little bit frustratring.
What do you think?
Best regards
Reinhard
PS: I have some additional Feature Request in the “pipeline”, but I would perfere to post them in separate threads - hope I will not be blamed for spamming
