Hello, NEWBIE here !
I’ve downloaded the WifiScope software and went step by step according to the instructions provided.
I’m having connectivity issue between the WifiScope software and my mount wifi.
My question is, I have the Wifiscope software on my laptop PC running and my wifi connection is on with my mount.
In sky safari 7 plus, I did the configuration that match with the WifiScope config.
After the set up process finished in Sky Safari, I tested the connection, and it verified connection.
The config I chose MEAD LX200 CLASSIC, EQ GoTo ( German)
When I try to connect I get a Connection failure. That says:
SKY SAFARI 7 PLUS CANT MAKE A WIRELESS NETWORK CONNECTION TO THE SCOPE, MAKE SURE YOU’VE JOINED ITS WIFI NETWORK AND GIVE PERMISSION SKYSAFARI 7 PLUS TO ACCESS YOUR LOCAL NETWORK.
Thank you
Roy Mixon
