I’m on my way to fully automated now that I’ve bought SGPro, thanks for the great software !
One thing I would like included is to automate the opening and closing of a remote telescope cover. Ideally support for the Alnitak ‘Flip Flat’ control sequence (that could also be used as a telescope cover and flats box). I’m in the process of making my own based on an Arduino which would respond to the same commands and think this would be a nice feature to add if at all possible.
I created an Arduino implementation of this a while back. You can find the code here if you’re interested. It’s meant to be a shell. Fill in the “blanks” for how your hardware actually communicates.
And yes, flip flat and flatman devices are fully supported.
Yes, it opens it on sequence start and closes it on sequence end. Also closes it for bias, darks, and flats. Light is only on for flats. If you mix frame types it will open/close and turn on/off depending on the current frame type.
Yes Robert - opens/closes as needed. Also -once you set up the light intensity/duration initially (using the Flats Calibration Wizard) then it also does what it needs to do when you have flats in the sequence…altogether a very nice addition to the arsenal.
In SGPro do you send the port commands directly to the Alnitak unit i.e. P000CR for ping ? I expect so but you might use an Optec dll or the AAcmd program which I may have to emulate.
SGP does send the Alnitak commands directly to the COM port. You can still emulate an Alnitak by setting up a virtual COM port and intercepting the commands. That’s what I did with this Alnitak emulator for Spike-a flat panels. You’re welcome to the source code (C++) if you are interested.
I have the FLIPFLAT and can’t get it to work with SGP version 2.4.3.25 I can open the FlipFlat, Close it and also turn it on but if I try to run a Flat sequence the FlipFlat is turned off, so I get no light. I have used the FlipFlat to setup initial flats. Every time I try to use SGP for the flats it turns the light off. I try the slider to set the light level to 100 but it slides it back to 0.
There were some changes for the FlipFlat added in 2.5 and has been reported working by a handful of users. Please try that version. If you still have issues please post a log.
Downloaded 2.5.0.22 and gave it a try. Still the same problem. Light turns off when starting sequence. I even tried to use the Flats Calibration Wizard but still the light is turned off.
Just thinking that you may not have set it up this way:
Obviously you only need the light when taking flats…so you need to set the brightness level here for particular filters…
Probably not where you expect it…but in with the filter set up. When you set the brightness here, you can use the Flats Calibration and that will stick with whatever profile you have set it for…i.e. if you are good with the calibration, you will not have to adjust this brightness parameter anytime you do flats in that profile.
The light will come on automatically (at the level set) when you select to do flats.
Ya… this is not super intuitive. I know this is not the answer, but, 2.5 will at least provide an easier way to get to the “semi-hidden” location of “flat box per-filter” settings. I have also reworked the help file tyo be a bit more clear about what this part of the CP actually does:
