I’ve just about given up on using this wizard as 9 out of 10 times it crashes on saving after completion of a run, deleting the profile in the process. I’m running an ASI1600 with the ASI Filter wheel and Alnitak Flip Flap. Running the latest .94 release of SGP Pro. Message is "Unhandled exception has occurred in your application. If you click continue the application will ignore this error and attempt to continue. If you click Quit the application will close immediately
"Type ‘Newtonsoft.Json.Linq.JArray’ in Assembly 'Newtonsoft.Json.Version=4.5.0.0. Culture =neutral.PublicKeyToken=30ad4fe6b2a6aeed is not marked as serializable.
This has gone on for over a year as I reported on this board.
