Hi Lads,
I am redoing my darks library after having my camera back from a service and repair and a couple of things are proving troublesome as per the following screen captures: -
If I have made a change to my profile this pop up occurs and you can’t press the button to say yes or no, the only way I found to get rid of it was by doing an alt and tab and select a different window.
The second problem is that I wanted to connect my FW whilst it was doing the darks library whilst I remembered, after doing it and having not touched the settings it keeps now asking if I want to turn the cooler off, I have answered no multiple times and as you can see, the system is running at -15 which was my target temp.
The system has been running for 24 hours now whilst it created the library, it has sat virtually untouched and there is still another 8 hours to go.
Thoughts welcome please.
