While it should’t happen too often, it sometimes becomes necessary to manually adjust the number of frames captured (rather than lowering the number to capture). The most common reason for this is to enforce a sequence in your image file naming pattern. In order to do this, simply click on the fraction text (far right) for the event you are attempting to change:
