If you save your images to the same place on your computer every time you’re out, you can set the default location for new images. Once this is set, every new sequence will initialize itself with your default location. To set it, go to “Tools” -> “Options”. When the Options dialog is open, simply set and save the “Default image directory” field and you’re done.
awesome thanks! any way I can set the default + targetname? that way it will save into the astro-images dir but will have its own name. (or even a date?) I could rename later?
Also does the directory have to be already created? it’s a pain to put image dir for a target then to into the dir and create its subdir then have it set that. A default would be nice.
