I have an AP1600 goto mount and an SBIG ST2000XM camera. Having difficulty with last few steps of connecting SGP with PHD2. I have the correct API loaded. PHD2 starts up, but after a while, it gives up. This message in the log, which was received repeatedly, may give a clue:
[05/31/20 22:23:58.536][DEBUG][PHD2 Listener Thread][SQ;] Failed to establish client connection to PHD2 using port 4400: No connection could be made because the target machine actively refused it 127.0.0.1:4400
I now have ‘enable server’ checked, and I still have basically the same problem – even when I am totally running simulators. I am really frustrated – this has been going on for months now.
You should be able to right click on the shortcuts and go to properties. One of the options is “Run As Administrator” this should be unchecked on both SGP and PHD2. Also if this is set you’ll get a UAC prompt whenever you launch the app asking if it’s ok to run as admin so that should be a clue if this is set or not.
When I type either version of the netstat command, it produces a white-text-on-black-bacground window with quite a bit of information in it but the window immediately closes, before I can either read it or even take a screen shot. So I don’t know what it said. How do I get it to either slow down or allow me to retrieve what it wrote?
Sorry, and thanks for your patience!
I hadn’t use the CMD prompt in many years, pardon me for being rusty.
When I type the netstat command it doesn’t output anything.
