Direct Mount Guider Dither for Paramount using Direct Guide
I’m finding that extreme dither is not moving very far when using Direct Mount Guider and Direct Guide with my Paramount MX/FSQ85 (native F/R). Is there anything I can do to make the movement larger ? The movement is larger than with the smaller dither amounts so the movement is scaling up but just not as much as I would like.
SGPRO 3.0.1.0
Many thanks
Robert
There is a setting in PHD2 too, which together with the SGP setting, determine the magnitude. You need to also realize that these figures are a maximum value, the dither amount is a random figure, up to the maximum and many times, you will find the dither is extremely small. I am using a FSQ85 with a MX right now and it is dithering just enough. I’ll share my settings when I next power up.
In PHD2 brain - I have 0.6 for scale. In SGP I use medium or small. I see the blips on the PHD2 trace and everything is good.
For the direct mount guider we just pulse a differing amount of time
  • Small 100ms
  • Medium 250ms
  • High 500ms
  • Extreme 1000ms
You can try upping your guide rate if you have that option which should essentially scale this value. I’m not sure if you have that option or not with your mount.
