Displaying sensor temperature?
Is there any way of showing the sensor temperature other than just showing that it’s switched on or off?
Are you talking about camera temperature or focuser temp (ambient outside
temp)? Either way, if you have the Temperature module or the Focus Control
module open you should see the temperature. Also in the control panel
under Camera tab or Focus Tab. Whether it is shown or not may depend on
the ascom driver for your equipment.
Joelshort - Camera temperature. I can see where to set-up temperature cooling and warm up in the control panel. What I would like to do is be able monitor the sensor temperature before, during and after a sequence of exposures. Even if it was just a green light to say that the sensor is at the set temperature…
Right, if you look at the Temperature module, the first number is where the
camera temp ACTUALLY is. The second number is your setpoint. So for
example I set my camera temp to -20C but it usually displays something
else. So my module temps would show “-19.7 / -20”
Or am I totally misunderstanding what you’re asking?
Thanks - that’s what I’m looking for, somehow missed it or it hadn’t registered with the grey cells! New to SGP’s learning curve…
Joelshort - turned out to be the camera PID number being wrong when making driver selections…
