Hello, my mount is a 10Micron mount which creates a model via platesolving and requires no auto guiding. In SGP, as I wanted to have dithering, I used the option Direct Mount under Guiding Interface and Very High (or something similar) every 1 frame. As far as I can tell when checking light frames, they were all perfectly aligned. Was I correct to use Direct Mount or should I have clicked on No Auto Guider (if I recall). I drive the mount via Ascom driver in SGPro. Thank you
