Hello, I couldn’t find the difference. between Sync, Target Offset and Scope Offset in the equipment telescope tab. I’m using a 10Micron and was trying to figure out what each option would achieve.
Thank you
You almost certainly want to use “Sync”. The other two options handle the sync somewhat internally by creating an offset while doing a plate solve. In about 90% of cases Sync is what you want though. If you find that the “Auto Center” keeps hunting over multiple (over 3) iterations, then you may want to experiment with the other two.
