Sometimes SGP runs nice and without problems. But often it stops with the notification: SGP does not react anymore. Two days ago during daytime with only the camera connected (QHY8L) making darks and flats SGP stopped after 20 minutes or sooner. Once it was still running after 6 hours, but most of time it stops reacting. I have a new Lenovo computer with Windows 10, i& processor and lots of memory. Anybody an idea?
I almost switched to Nebulosity but then one night SGP was working properly. So I was very happy. I made the sequence larger so it would go on making pictures of M51 until sunrise. Alas next morning it turned out it had stopped a few minutes after I went to bedâŚ
I like this program, but other users say it never halts but with me it much more often halts then it is continuing as it should be, please help
Thanks for answering, but is does not bring me further . So I politely ask more:
I cannot find the search functionality under âhelpâ in SGP - Maybe I am to old and to stupid for this, but I canât helpâŚ
I will try again, (I did but maybe the wrong way? ) try to use forum searchâŚ.
Here in our Dutch language community at Starry-night.nl http://starry-night.nl/ none of the SGP users have met the problem âSeguence Generator reageert niet meerâ So I seem to be very uncommon, so I felt free to start a topic on this issue.
Of course I feel very sorry about that, but please, as a paying customer I kindly and politely ask: help me where to find a solution for my problems
with kind regards, yours sincerely
Arie
P.S. English is not my native language, please sorry for the mistakes.
the issue âSGP does not reactâ occurs some nights always, also by day with only the camera connected and making Darks. Ans other nights it does not occur at all with the same equipment.
I will attach a SGF file too,
yours sincerely,
Arie
Arie,
I see a LOT of errors in that log with your camera. How do you have the camera connected? Are you going through a hub? Can you try a different USB cable and connect it directly to your imaging machine?
Since a few weeks my new PC - Lenovo is on a table besides the pier. I bought âclicktronicâ USB cables with goldplated connectors, which should be extreme reliable, at least the price was extreme ;o). Almost all equipment is connected with my PC directly except the filterwheel.
My Trius SX-35 camera has a hub inside the camera housing, but I use it only for the filterwheel, but I will change to a cable directly to the PC. I will change the cables and tie them up to the Cameraâs, focuser and filterwheel. I did use a âicron ranger USB 2.0 2304 when my PC is inside but that should be a big lot better quality as an USB hub.
But I must admit the SX-Lodestars x2 guiding camera has a poor USB mini socket and also the Main camera often loses power connection, so I did yesterday improve this.
The problem of the sometimes occurring âAscomâ errors when using the Trius SX-35 and the SX Lodestar I brought to Starlight Xpress but no answer until now.
So I will change this all and keep you informed, last night I went to bed at 03.30 and SGP continued correctly, making subs until 04:31. Because of it was getting light and PHD2 stopped guiding, the last two pictures were to whit.
I am afraid your program SGP is very unstable. When it halts because of a bad connection - why does it not give a message for bad or lost connection?
I am very sorry because it is very intuitive and has almost all possibilities. Christoph helped me two nights when I was in Botswana, he did not solve the problems but promised me it would be a lot better at home with my Mesu200 mount. Het did help me indeed but later on the problems started.
So give me please an honest advise:
Switch to Nebulosity or Maxim? Or do you have a good solution?
Windows 7 on the new computer and try again?
Arie,
Sorry youâre having problems. But we have thousands of users not having issues like this so I think itâs a little unfair to say our application is unstable. Unfortunately most driver communication is very low level and we donât have a chance to catch those exceptions we catch what we can but some bubble up to the top.
I canât tell you what to do. Itâs your money and decision to make. Sounds like you know that the camera has a poor power connection that has caused problems. I think itâs pretty unfair to blame us when you actually know what the issue is. But if you feel another application is the right choice to make thatâs your decision. Imaging is certainly about finding what works well for you.
Hello Jared
I confess you are right. Your program is the most intuitive and it is worth to me three times of the cost of it so âŹ300 if it runs adequate on my machines.
Yes the Trius Rasa has poor power connection. And the Lodestar has a poor USB mini connection. So tonight I will try with an Atik and a Asi ZWO camera as guidercamers
At least the ascom error must dissappear which I get when trying to use the SX cameraâs
I leave for three weeks to France and will try many possibilities
Thanks for reaction help and correction
Greetings Arie
Absolutely. We catch a fair amount of these errors as I saw in your log. But eventually something bad happens and SGP quits. When a device suddenly disappears bad things can happen!
While using Nebulosity with my Trius SX-35 camera I found out that this camera is probably the cause of all? problems. It loses connection inside and does not give answer. That is when SGP does not react anymore!! It is just a pity SGP does not tell whyâŚ. But Nebulosity did:
So I have to apologize for blaming SGP for the problems I did have. Please forgive me?
So the Trius must go back and I am gonna use the Atik 414 camera. I Hope I will find out how to do plate solve with this camera.
Do I have to change the FOV in the Platesolve settings or does PS pick all dat from the picture taken?
If you do a blind solve it should all be populated from the camera. However youâll likely need to populate the Height and Width of CCD in the camera settings.
Also SGP did report a similar error about timeout in the logs. However with just a single failure itâs hard to know if itâs the application of the hardware that is the issue.
Yes, if you go to Tools>>Options on your old machine you can see where the âProfiles Directoryâ is located. Just copy the profiles from that directory into the corresponding âProfiles Directoryâ on the new machine.
Since 2 weeks I have the Trius SX35 again on the RASA, but a lot of trouble, SGP NEVER worked nicely. The Trius is repaired it had a bad power supply connectorâŚâŚ
On the contrary SGP worked very nice with the QHY8Pro and the Atik 414.
Today I received a message from Starlight Xpress: SGP can not work with 2 Starlight Xpress cameraâs so the Trius and the Lodestar can not work at the same time in SGP. Did you know? Do you agree? I think I have to agree and start looking for an other guide camera.
Iâm not sure what you think SX told you, but you can use two SX cameras with SGP/PHD. For about 2 years I used a Trius SX694 and Lodestar guider with no problems.
Well SX employe told me SGP could not handle 2 SX cameras and indeed I have allways problems. And when I use a Qhy8pb or the Atik 414 camera with the Lodestar guide canera in SGP it runs almost on its own.
So why does it not work here?
Regards Ary
SGP can only connect one camera at a time. The Lodestar connects through
PHD. But that has nothing to do with SX. You should be able to use both a
main SX camera and SX guide camera (main camera with SGP, guide camera with
PHD).
Did you properly install the ascom driver for both a SX main camera and SX
guide camera? The installer asks you if you have each of those cameras.
Also, which camera are you choosing in PHD2? There are two you can choose
Starlight Xpress SXV
Starlight Xpress Guider (ASCOM)
I have had better success with Starlight Xpress SXV.
