Hi
I can no longer import my observing list from DSO to SGP ver. 2.6.1.114. When I try, I get this message “error importing data”
This my list https://dso-browser.com/list/875349e1
- John
Hi
I run the most recent version but have the same issue. Error message: The image specified did not return any valid location data! Make sure the image has been solved properly by the host system.
I have to roll back to ver. 2.6.0.25 to make it work, otherwise I get an error message and the SGP closes.
very frustrating - i have the same problem - also uninstalled and reinstalled the program as well
URGH- hope they fix it before the next new moon…
Is there help on the way? here is a log file…
https://www.dropbox.com/s/50lxuywqeare2nl/sg_logfile_20181203145504.txt?dl=0
The last time I had an error importing from DSO browser it had to do with my region settings I had to change the comma(,) to a dot(.) or the other way around. Just try and see if it helps?.
thanks but ---- What comma ???
I have
https://dso-browser.com/observing-lists/fXXXX with the numbers at the end
still crashing
cheers
Karen
Hi Johan
they are the same as you show
unchanged from when this worked - i think DSO has changed something not SGP
cheers
Karen
I have contacted Sebastian(DSO Browser) and he believes that the problem lies with SGP …
Hi Karen,
Not sure what else to suggest. DSO was working 100% the last time I imported a target. That was about a week or two ago. I will check again tonight.
I don’t see how - it has only happened since the implemented the new multiple observing list options - Although maybe i am wrong - my old list stopped working and I have a new list location and it doesn’t work at all - I’ve sent an email to DSO as well - I guess I will get the same reply
lets see what SGP says … eventually…
could it be as simple as ???
https://dso-browser.com/observing-lists/XXabcd00
When it should be
https://dso-browser.com/list/XXabcd00
edited:
I’ve just rolled back a few versions - like John1 - it does work in the version - 2.6.0.25 with this format https://dso-browser.com/observing-lists/XXabcd00. im keeping this version until the newer versions bugs are fixed.
K
Just got this when trying to list my Observation list on DSO, So I think the problem seems to be DSO. I also managed to get my list by hitting CTRL-F5 on Chrome forcing a refresh of the page. I will try tonight to see if I have any luck with SGPRO and DSO
Hi Karen,
I just tested loading What's in the Sky Tonight? into Sequence Generator Pro 3.0.3.151 and it works 100%. Sorry I can not help any further.
Regards
Johan
Hi Johan
thanks
It works in 2.6.0.25 as well but not in any later version.
cheers
Karen
