DSO-Browser List Import Error
I like to take advantage of the DSO-Browser website to line up my targets for the night. Unfortunately, the import function for SGP (2.6.0.23) is now generating the following error when I run it:
[07/16/17 18:02:24.376][DEBUG] [Main Thread] DSOBrowser: Error fetching object list! - The request was aborted: Could not create SSL/TLS secure channel.
Does anyone have any clues as to what might be the problem on my end? Is this a website error caused by the DSO-Browser site or is it something that I have set incorrectly in SGP?
Thanks in advance for any help.
Jim
If you can post the link to the target or list you were attempting to import we can check it out.
Sorry, Jared. I should have posted it in initial post.
https://dso-browser.com/list/7c11b243
Jim
I am also attaching the SGP log with error note. Any idea where the problem may lie?
Jimsg_logfile_20170722160009.txt (33.3 KB)
Hi, I get the following error when trying to import from DSO Browser:
[07-25-17 14:24:44.976][DEBUG] [Main Thread] DSOBrowser: Requested dso list at https://dso-browser.com/list/e0bfddc6, awaiting response…
[07-25-17 14:24:45.259][DEBUG] [Main Thread] DSOBrowser: Error fetching object list! - Anulada la solicitud: No se puede crear un canal seguro SSL/TLS.
[07-25-17 14:24:45.259][DEBUG] [Main Thread] DSOBrowser: DSOBrowser object list is null
I tried on two PC’s and the error is the same. I will appreciate any help,
Renan.
I am more convinced that the dso-browser.com site is causing the problems with importing to SGP. Will try to contact them for any assistance.
Jim
Hi folks,
I discussed this issue with Sebastian and we worked this issue out. Existing versions of SGPro should be functional again.
