Hi Everyone,
I was just trying if I can connect my camera in SGPO - looks like not supported ? Please shed a light on this, maybe I am doing something wrong,
Clear skies,
Janos
Hi Everyone,
Clear skies,
Janos
Do you have the camera in Manual mode? Can you post your logs? I think you’re the first person attempting to use SGP with a T5.
Having said that it should work ok. I’ll have to check to see if there are any updates to the Canon SDK to make sure.
Well it looks like it’s probably an SDK issue. I’ll get a hold of the new DLLs this evening and provide you with some instructions to get them into SGP and we’ll update these in our next release.
Hi Jared,
You are so quick, thanks for that
! My logfile says:
[10/10/2014 16:37:57] [DEBUG] [Main Thread] Licensing: Machine ID found…
[10/10/2014 16:38:01] [DEBUG] [Main Thread] Licensing: Request for licenses successful, writing
cookie…
[10/10/2014 16:38:01] [DEBUG] [Main Thread] Licensing: Applying licenses…
[10/10/2014 16:38:01] [DEBUG] [Main Thread] Licensing: Licenses applied…
[10/10/2014 16:38:05] [DEBUG] [Main Thread] Error initializing API (tried to unblock port): Toegang
geweigerd
[10/10/2014 16:38:05] [DEBUG] [Main Thread] Error reading PHD log. De objectverwijzing is niet op een
exemplaar van een object ingesteld.
[10/10/2014 16:38:05] [DEBUG] [Main Thread] Error loading notification settings! Kan bestand C:\Users
\Janos\AppData\Local\SequenceGenerator\Sequence Generator Pro\notifications.sgd niet vinden.[10/10/2014
16:38:05] [DEBUG] [Main Thread] Error loading email endpoint addresses! Kan bestand C:\Users\Janos
\AppData\Local\SequenceGenerator\Sequence Generator Pro\emailEndpointAddresses.sgd niet vinden.
[10/10/2014 16:38:05] [DEBUG] [Main Thread] ===== S E Q U E N C E G E N E R A T O R (v2.3.15.2568)
[10/10/2014 16:38:05] [DEBUG] [Main Thread] Interface: Sequence Generator Pro
[10/10/2014 16:38:05] [DEBUG] [Focuser Thread] Entering Fouser message dispatch loop…
[10/10/2014 16:38:05] [DEBUG] [Camera Thread] Entering camera message dispatch loop…
[10/10/2014 16:38:05] [DEBUG] [TEC Thread] Entering TEC message dispatch loop…
[10/10/2014 16:38:05] [DEBUG] [Filter Wheel Thread] Entering Filter Wheel message dispatch loop…
[10/10/2014 16:38:05] [DEBUG] [Rotator Thread] Entering Rotator message dispatch loop…
[10/10/2014 16:38:05] [DEBUG] [Auto Guider Thread] Entering Auto Guider message dispatch loop…
[10/10/2014 16:38:05] [DEBUG] [Auto Guider Error Thread] Entering Auto Guider message dispatch loop…
[10/10/2014 16:38:05] [DEBUG] [Dome Thread] Entering Dome message dispatch loop…
[10/10/2014 16:38:05] [DEBUG] [Telescope Thread] Entering Telescope message dispatch loop…
[10/10/2014 16:38:05] [DEBUG] [Main Thread] Settings changed (or loaded)…
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingMdiAutoStretch = False
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingIgLastFileFolder =
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingFormScaleWarning = False
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingDelayBetween = 0
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingFliFlushLow = 0
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingSBIGLpt2Address = 278
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingMdiMouseAction = Stretch
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingLastAscomCamera =
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingAutoRecoveryActive = False
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingTemperhumInterval = 300
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingASCOMWarningShown = False
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingPlateCamScale = 0
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingInterface =
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingLastAscomFilterWheel =
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingAstroArtDisplayInstructions = True
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingSBIGLpt1Address = 378
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingTrialQuestionsAsked = False
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingMdiLastImageDir =
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingDelayFirst = 0
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingMfPosition = {X=0,Y=0}
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingSoundAttention =
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingPinpointCatalog =
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingCameraOverhead =
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingPlateSolveOn = False
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingAstrometryNetEndpointList =
System.Collections.Specialized.StringCollection
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingSBIGGuider = None
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingNaggerText =
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingMdiPhdDisplay = RA/Dec
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingMdiShowToolStrip = True
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingMdiShowCrosshairs = True
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: WindowGeometry =
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingIgRenameStringLocation = 2
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingIgSubFolders = False
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: WindowGeometrySearch =
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingOffset = -1
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingAutoStretchLevel = Low
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingTemperHumUnits = C
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingBasename =
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingHfrColor = Color [RoyalBlue]
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingSBIGFanOffWithTec = False
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingMdiSize = {Width=800, Height=600}
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingIgCopyAndRenameFiles = False
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingNagger = False
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingImportFromCfw = True
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingMdiShowStatusTrip = True
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingShowTooltipHelp = True
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingLastUpdateCheck = 1/01/2012 0:00:00
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingCpPosition = {X=0,Y=0}
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingSBIGCfwPort =
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingMdiLocation = {X=0,Y=0}
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingIgLastCsvFolder =
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingSBIGFilterWheel = Auto Detect
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingSBIGConnection = USB
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingAutoSave = True
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingFirstTime = True
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingFliFlushHigh = 0
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingMdiState = maximized
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingUseSequenceOptions = False
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingSoundCompleted =
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingTrialExpiredShown = False
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingTemperHumColor = Grey
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingDataDirectory =
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingCanonFileFormat = Single Image (CFA FITS)
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingAlnitakComPort =
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingIgRenameFiles = False
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingSubFolder = True
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingLastSGSaveFolder =
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingNikonDataFormat = FITS
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingPlaySounds = False
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingLastNikonType = Auto Connect
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingLastSequenceStart = 1/01/0001 0:00:00
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingLastAscomTelescope =
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingMdiPhdScale = 100
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingIgRenameType = 0
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingMdiPhdRaColor = Color [Blue]
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingLastImageSaveFolder =
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingEnableImageHistory = False
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingFinishFullEvent = True
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingMosaicOverlap = 20
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingQSIFanOffWithTec = False
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingRecentSequences =
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingDefaultDirectory =
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingMdiPhdDecColor = Color [Red]
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingAstrometryNetEndpoint =
http://nova.astrometry.net/api
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingSBIGCfwUseRS232 = False
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingStarsColor = Color [OrangeRed]
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingIgOverwriteExisting = False
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingLastAscomFocuser =
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingIgLastFolder =
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: WindowGeometryOpen =
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingNumEvents = 5
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingPlateCamBlank =
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingTempFiles = C:\Temp
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingSBIGEthernetIP = 0.0.0.0
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingSBIGLpt3Address = 3BC
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingIgCopyLocation =
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingSBIGAutoDetectIp = True
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingAstroArtStartApp = True
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingMicroTouchLocation =
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingMdiPhdZoom = 40
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingMdiNewWindow = False
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingAfTestPackPath =
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingEventAlwaysVisible = False
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingGain = -1
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingLastAscomDome =
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingLookForTemperDevices = False
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingLastAscomRotator =
[10/10/2014 16:38:05] [DEBUG] [Main Thread] * SETTING: settingControlPanelOnTop = False
[10/10/2014 16:38:05] [DEBUG] [Main Thread] Performing initialization…
[10/10/2014 16:38:05] [DEBUG] [Main Thread] Creating new sequence with no profile
[10/10/2014 16:38:05] [DEBUG] [Main Thread] Performing full form reset (with default data)…
[10/10/2014 16:38:05] [DEBUG] [Main Thread] Retreiving new equipment objects…
[10/10/2014 16:38:05] [DEBUG] [Main Thread] New camera object (No Camera) dispatched…
[10/10/2014 16:38:05] [DEBUG] [Main Thread] New filter wheel object (No Filter Wheel) dispatched…
[10/10/2014 16:38:05] [DEBUG] [Main Thread] New focuser object (No Focuser) dispatched…
[10/10/2014 16:38:05] [DEBUG] [Main Thread] New telescope object (No Telescope) dispatched…
[10/10/2014 16:38:05] [DEBUG] [Main Thread] New rotator object (No Rotator) dispatched…
[10/10/2014 16:38:05] [DEBUG] [Main Thread] New dome object (No Observatory) dispatched…
[10/10/2014 16:38:05] [DEBUG] [Main Thread] New flat box object (No Flat Box) dispatched…
[10/10/2014 16:38:05] [DEBUG] [Main Thread] New auto guider object (No Auto Guider) dispatched…
[10/10/2014 16:38:05] [DEBUG] [Main Thread] New plate solver object (No Plate Solver) dispatched…
[10/10/2014 16:38:05] [DEBUG] [Main Thread] Populating the form controls…
[10/10/2014 16:38:05] [DEBUG] [Main Thread] Added row 0…
[10/10/2014 16:38:05] [DEBUG] [Main Thread] Added row 1…
[10/10/2014 16:38:05] [DEBUG] [Main Thread] Added row 2…
[10/10/2014 16:38:06] [DEBUG] [Main Thread] Added row 3…
[10/10/2014 16:38:06] [DEBUG] [Main Thread] Added row 4…
[10/10/2014 16:38:06] [DEBUG] [Main Thread] Added row 5…
[10/10/2014 16:38:06] [DEBUG] [Main Thread] Loading custom filter names…
[10/10/2014 16:38:06] [DEBUG] [Main Thread] PopulateDataModel: Transferring view to the data model…
[10/10/2014 16:38:06] [DEBUG] [Main Thread] Retreiving new equipment objects…
[10/10/2014 16:38:06] [DEBUG] [Main Thread] New camera object (No Camera) dispatched…
[10/10/2014 16:38:06] [DEBUG] [Main Thread] New filter wheel object (No Filter Wheel) dispatched…
[10/10/2014 16:38:06] [DEBUG] [Sequence Thread] Entering sequence message dispatch loop…
[10/10/2014 16:38:06] [DEBUG] [Main Thread] New focuser object (No Focuser) dispatched…
[10/10/2014 16:38:06] [DEBUG] [Main Thread] New telescope object (No Telescope) dispatched…
[10/10/2014 16:38:06] [DEBUG] [Main Thread] New rotator object (No Rotator) dispatched…
[10/10/2014 16:38:06] [DEBUG] [Main Thread] New dome object (No Observatory) dispatched…
[10/10/2014 16:38:06] [DEBUG] [Main Thread] New flat box object (No Flat Box) dispatched…
[10/10/2014 16:38:06] [DEBUG] [Main Thread] New auto guider object (No Auto Guider) dispatched…
[10/10/2014 16:38:06] [DEBUG] [Main Thread] New plate solver object (No Plate Solver) dispatched…
[10/10/2014 16:38:06] [DEBUG] [Main Thread] Checking if version check is required…
[10/10/2014 16:38:06] [DEBUG] [Cleaner Thread] Running cleanup…
[10/10/2014 16:38:06] [DEBUG] [Cleaner Thread] Cleaning 0 files in directory C:\Users\Janos\AppData
\Local\SequenceGenerator\Temp.…
[10/10/2014 16:38:06] [DEBUG] [Cleaner Thread] Cleaning finished…
[10/10/2014 16:38:06] [DEBUG] [Main Thread] UI layout found, loading layout at C:\Users\Janos\AppData
\Local\SequenceGenerator\sg_ui_config.xml
[10/10/2014 16:38:11] [DEBUG] [Main Thread] Connecting camera in main thread…
[10/10/2014 16:38:16] [DEBUG] [Main Thread] Error in EdsOpenSession. Error: EDS_ERR_NOT_SUPPORTED
Jared,
Not to forget to mention: the camera is in manual mode.
Clear skies,
Janos
Thanks Janos,
Manual mode won’t make a difference at this point. I’ll try to get the DLLs to you this evening which should take care of things.
Thanks, I am looking forward to test !
Can you try replacing the DLLs found in c:\Program Files(x86)\Sequence Generator with the DLLs in the zip below
https://dl.dropboxusercontent.com/u/25320932/EDSDK-2.14.zip
That should get things going. Having said that I haven’t tested these at all. I’ll run through some tests this evening but wanted to get these to you ASAP.
Hi Jared,
You nailed it ! I have now the EOS 1200D connected :-). Just tried a 50s exposure - works via USB connection. Frame & focus and live view works as well.
Thanks a ton !
Clear skies,
Janos
Excellent! We’ll package those up with our next release.
Hi Jared,
I’m getting the same message with a Canon 70D. Is that not supported?
Neil
Oh, disregard…I copied the DLLs in your earlier reponse…all good now!
Those DLLs should be getting bundled up with SGP. I’ll verify that they are. Was this with 2.4 or 2.3?
