“EDS_ERR_NOT_SUPPORTED” message with Canon 760D
I was trying to connect my new EOS 760D camera in SGP (version 2.4.2.11) but get the error “Error in EdsOpenSession. Error: EDS_ERR_NOT_SUPPORTED”. I have put the camera in manual mode so I think that is OK. Trying to connect with the Canon EOS Utility (version 3) works fine.
Can you give me some advice on what i’m doing wrong?
This is what is in the logfile:
[9-10-2015 21:31:54] [DEBUG] [Main Thread] Licensing: Machine ID found…
[9-10-2015 21:31:54] [DEBUG] [Main Thread] Checking for valid internet connection…
[9-10-2015 21:31:54] [DEBUG] [Main Thread] Valid internet connection detected…
[9-10-2015 21:31:55] [DEBUG] [Main Thread] Licensing: Request for licenses successful, writing cookie…
[9-10-2015 21:31:55] [DEBUG] [Main Thread] Licensing: Applying licenses…
[9-10-2015 21:31:55] [DEBUG] [Main Thread] Licensing: Licenses applied…
[9-10-2015 21:31:55] [DEBUG] [Main Thread] SGPro retail license…
[9-10-2015 21:31:56] [DEBUG] [Main Thread] API successfully started on port 59590…
[9-10-2015 21:31:56] [DEBUG] [Main Thread] Error loading notification settings! Could not find file ‘C:\Users\Jacques\AppData\Local\SequenceGenerator\Sequence Generator Pro\notifications.sgd’.
[9-10-2015 21:31:56] [DEBUG] [Main Thread] Error loading GNS endpoint settings! Could not find file ‘C:\Users\Jacques\AppData\Local\SequenceGenerator\Sequence Generator Pro\gnsSettings.sgd’.
[9-10-2015 21:31:56] [DEBUG] [Main Thread] Error loading email endpoint addresses! Could not find file ‘C:\Users\Jacques\AppData\Local\SequenceGenerator\Sequence Generator Pro\1-emailEndpointAddresses.sgd’.
[9-10-2015 21:31:56] [DEBUG] [Main Thread] Error loading email endpoint addresses! Could not find file ‘C:\Users\Jacques\AppData\Local\SequenceGenerator\Sequence Generator Pro\2-emailEndpointAddresses.sgd’.
[9-10-2015 21:31:56] [DEBUG] [Main Thread] Error loading email endpoint addresses! Could not find file ‘C:\Users\Jacques\AppData\Local\SequenceGenerator\Sequence Generator Pro\3-emailEndpointAddresses.sgd’.
[9-10-2015 21:31:56] [DEBUG] [Main Thread] Error loading text file endpoint data! Could not find file ‘C:\Users\Jacques\AppData\Local\SequenceGenerator\Sequence Generator Pro\1-textFileEndpointSettings.sgd’.
[9-10-2015 21:31:56] [DEBUG] [Main Thread] Error loading text file endpoint data! Could not find file ‘C:\Users\Jacques\AppData\Local\SequenceGenerator\Sequence Generator Pro\2-textFileEndpointSettings.sgd’.
[9-10-2015 21:31:56] [DEBUG] [Main Thread] Error loading text file endpoint data! Could not find file ‘C:\Users\Jacques\AppData\Local\SequenceGenerator\Sequence Generator Pro\3-textFileEndpointSettings.sgd’.
[9-10-2015 21:31:56] [DEBUG] [Main Thread] ===== S E Q U E N C E G E N E R A T O R (v2.4.2.11) =====
[9-10-2015 21:31:56] [DEBUG] [Main Thread] OS: Microsoft Windows 7 Professional
[9-10-2015 21:31:57] [DEBUG] [Focuser Thread] Entering Fouser message dispatch loop…
[9-10-2015 21:31:57] [DEBUG] [TEC Thread] Entering TEC message dispatch loop…
[9-10-2015 21:31:57] [DEBUG] [Camera Thread] Entering camera message dispatch loop…
[9-10-2015 21:31:57] [DEBUG] [Filter Wheel Thread] Entering Filter Wheel message dispatch loop…
[9-10-2015 21:31:57] [DEBUG] [Rotator Thread] Entering Rotator message dispatch loop…
[9-10-2015 21:31:57] [DEBUG] [Auto Guider Thread] Entering Auto Guider message dispatch loop…
[9-10-2015 21:31:57] [DEBUG] [Auto Guider Error Thread] Entering Auto Guider message dispatch loop…
[9-10-2015 21:31:57] [DEBUG] [Dome Thread] Entering Dome message dispatch loop…
[9-10-2015 21:31:57] [DEBUG] [Telescope Thread] Entering Telescope message dispatch loop…
[9-10-2015 21:31:57] [DEBUG] [Main Thread] Settings changed (or loaded)…
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingMdiAutoStretch = False
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingIgLastFileFolder =
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingFormScaleWarning = False
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingDelayBetween = 0
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingFliFlushLow = 0
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingSBIGLpt2Address = 278
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingMdiMouseAction = Stretch
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingLastAscomCamera =
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingAutoRecoveryActive = False
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingTemperhumInterval = 300
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingASCOMWarningShown = False
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingPlateCamScale = 0
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingCanonMirrorSettle = 0
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingInterface =
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingLastAscomFilterWheel =
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingAstroArtDisplayInstructions = True
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingSBIGLpt1Address = 378
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingTrialQuestionsAsked = False
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingMdiLastImageDir =
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingTemperHumUserTempComp = 0
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingDelayFirst = 0
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingFliNormalSpeedMode = 0
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingFliHighSpeedMode = 0
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingMfPosition = {X=0,Y=0}
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingSoundAttention =
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingPinpointCatalog =
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingCameraOverhead =
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingPlateSolveOn = False
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingAstrometryNetEndpointList = System.Collections.Specialized.StringCollection
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingSBIGGuider = None
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingQSIFanSpeed = 2
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingNaggerText =
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingMdiPhdDisplay = RA/Dec
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingMdiShowToolStrip = True
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingMdiShowCrosshairs = True
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: WindowGeometry =
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingIgRenameStringLocation = 2
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingIgSubFolders = False
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: WindowGeometrySearch =
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingOffset = -1
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingAutoStretchLevel = Low
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingTemperHumUnits = C
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingProfileDirectory =
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingBasename =
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingHfrColor = Color [RoyalBlue]
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingNikonAfBinning = 1
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingSBIGFanOffWithTec = False
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingLastAscomSafetyMonitor =
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingMdiSize = {Width=800, Height=600}
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingIgCopyAndRenameFiles = False
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingSimDownloadTimesAf = False
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingNagger = False
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingImportFromCfw = True
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingMdiShowStatusTrip = True
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingShowTooltipHelp = True
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingLastUpdateCheck = 1-1-2012 0:00:00
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingCpPosition = {X=0,Y=0}
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingSBIGCfwPort =
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingMdiLocation = {X=0,Y=0}
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingIgLastCsvFolder =
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingSBIGFilterWheel = Auto Detect
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingSBIGConnection = USB
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingDSLRSoftwareBinForAf = False
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingAutoSave = True
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingFirstTime = True
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingFliFlushHigh = 0
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingMdiState = maximized
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingUseSequenceOptions = False
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingSoundCompleted =
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingTrialExpiredShown = False
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingTemperHumColor = Grey
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingDataDirectory =
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingCanonFileFormat = Single Image (CFA FITS)
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingAlnitakComPort =
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingIgRenameFiles = False
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingSubFolder = True
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingLastSGSaveFolder =
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingNikonDataFormat = FITS
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingPlaySounds = False
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingLastNikonType = Auto Connect
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingLastSequenceStart = 1-1-0001 0:00:00
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingLastAscomTelescope =
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingMdiPhdScale = 100
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingIgRenameType = 0
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingTemperHumUserHumidityComp = 0
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingMdiPhdRaColor = Color [Blue]
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingLastImageSaveFolder =
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingEnableImageHistory = False
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingFinishFullEvent = True
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingMosaicOverlap = 20
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingQSIFanOffWithTec = False
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingRecentSequences =
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingDefaultDirectory =
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingMdiPhdDecColor = Color [Red]
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingAstrometryNetEndpoint = Astrometry.net
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingSBIGCfwUseRS232 = False
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingStarsColor = Color [OrangeRed]
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingPhd2InstallPath =
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingIgOverwriteExisting = False
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingLastAscomFocuser =
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingIgLastFolder =
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: WindowGeometryOpen =
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingNumEvents = 5
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingCanonAfBinning = 1
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingPlateCamBlank =
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingTempFiles = C:\Temp
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingFliHighSpeedDesc =
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingSBIGEthernetIP = 0.0.0.0
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingSBIGLpt3Address = 3BC
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingFliNormalSpeedDesc =
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingIgCopyLocation =
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingSBIGAutoDetectIp = True
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingAstroArtStartApp = True
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingSimDownloadTimesPlate = False
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingMicroTouchLocation =
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingMdiPhdZoom = 40
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingMdiNewWindow = False
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingEventAlwaysVisible = False
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingFliRbiMitigation = False
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingGain = -1
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingLastAscomDome =
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingLookForTemperDevices = False
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingLastAscomRotator =
[9-10-2015 21:31:57] [DEBUG] [Main Thread] * SETTING: settingAfTestPackPath =
[9-10-2015 21:31:57] [DEBUG] [Main Thread] Performing initialization…
[9-10-2015 21:31:57] [DEBUG] [Main Thread] Creating new sequence with no profile
[9-10-2015 21:31:57] [DEBUG] [Main Thread] Performing full form reset (with default data)…
[9-10-2015 21:31:57] [DEBUG] [Main Thread] Retreiving new equipment objects…
[9-10-2015 21:31:57] [DEBUG] [Main Thread] New camera object (No Camera) dispatched…
[9-10-2015 21:31:57] [DEBUG] [Main Thread] New filter wheel object (No Filter Wheel) dispatched…
[9-10-2015 21:31:57] [DEBUG] [Main Thread] New focuser object (No Focuser) dispatched…
[9-10-2015 21:31:57] [DEBUG] [Main Thread] New telescope object (No Telescope) dispatched…
[9-10-2015 21:31:57] [DEBUG] [Main Thread] New rotator object (No Rotator) dispatched…
[9-10-2015 21:31:57] [DEBUG] [Main Thread] New dome object (No Observatory) dispatched…
[9-10-2015 21:31:57] [DEBUG] [Main Thread] New flat box object (No Flat Box) dispatched…
[9-10-2015 21:31:57] [DEBUG] [Main Thread] New weather station object (No Safety Monitor) dispatched…
[9-10-2015 21:31:57] [DEBUG] [Main Thread] New auto guider object (No Auto Guider) dispatched…
[9-10-2015 21:31:57] [DEBUG] [Main Thread] New plate solver object (No Plate Solver) dispatched…
[9-10-2015 21:31:57] [DEBUG] [Main Thread] Populating the form controls…
[9-10-2015 21:31:57] [DEBUG] [Main Thread] Added row 0…
[9-10-2015 21:31:57] [DEBUG] [Main Thread] Added row 1…
[9-10-2015 21:31:57] [DEBUG] [Main Thread] Added row 2…
[9-10-2015 21:31:57] [DEBUG] [Main Thread] Added row 3…
[9-10-2015 21:31:57] [DEBUG] [Main Thread] Added row 4…
[9-10-2015 21:31:57] [DEBUG] [Main Thread] Loading custom filter names…
[9-10-2015 21:31:57] [DEBUG] [Main Thread] PopulateDataModel: Transferring view to the data model…
[9-10-2015 21:31:57] [DEBUG] [Sequence Thread] Entering sequence message dispatch loop…
[9-10-2015 21:31:57] [DEBUG] [Main Thread] Checking if version check is required…
[9-10-2015 21:31:57] [DEBUG] [Main Thread] UI layout found, loading layout at C:\Users\Jacques\AppData\Local\SequenceGenerator\sg_ui_config.xml
[9-10-2015 21:31:57] [DEBUG] [Cleaner Thread] Running cleanup…
[9-10-2015 21:31:57] [DEBUG] [Cleaner Thread] Cleaning 0 files in directory C:\Users\Jacques\AppData\Local\SequenceGenerator\Temp.…
[9-10-2015 21:31:57] [DEBUG] [Cleaner Thread] Cleaning multi camera registration file…
[9-10-2015 21:31:57] [DEBUG] [Cleaner Thread] Cleaning finished…
[9-10-2015 21:32:02] [DEBUG] [Main Thread] Connecting camera in main thread…
[9-10-2015 21:32:05] [DEBUG] [Main Thread] No Canon cameras detected! Error: EDS_ERR_OK
[9-10-2015 21:32:09] [DEBUG] [Sequence Thread] Dispatch loop: Received SGM_TERMINATE…
[9-10-2015 21:32:09] [DEBUG] [Auto Guider Thread] Auto Guider Dispatch loop: Received SGM_TERMINATE…
[9-10-2015 21:32:09] [DEBUG] [TEC Thread] TEC Dispatch loop: Received SGM_TERMINATE…
[9-10-2015 21:32:09] [DEBUG] [Telescope Thread] Telescope Dispatch loop: Received SGM_TERMINATE…
[9-10-2015 21:32:09] [DEBUG] [Camera Thread] Camera Dispatch loop: Received SGM_TERMINATE…
[9-10-2015 21:32:09] [DEBUG] [Focuser Thread] Focuser Dispatch loop: Received SGM_TERMINATE…
[9-10-2015 21:32:09] [DEBUG] [Filter Wheel Thread] Filter Wheel Dispatch loop: Received SGM_TERMINATE…
[9-10-2015 21:32:09] [DEBUG] [Main Thread] Performing clean up…
I think I solved the problem myself. I installed the EOS Utility from the supplied CANON DVD on my PC and copied the files EDSDK.dll and EdsImage.dll from the directory where the EOS utility was installed to the SGP directory. After that everything seems to work fine.
Would you be able to right click that file, go to the versions tab and post
what it says there. Seems like we might want to be distributing this new
version. Thanks.
These are the properties for both files:
Thank you.
The 2.4.3.10 beta now distributes EDSDK 3.2.20.2 (the latest Canon has available)
I have the problem back but now with a Canon 5D mark IV. The latest EDSDK.DLL is version 3.5.0.3.
Can you update the EDSDK files with the latest one’s?
Regards.
Eventually. The new SDK is not compatible with our software so we reverted it.
Any chance that the Canon 5D mark IV will be supported in the near future?
Absolutely… we just need to find out why SGPro does not appear to be compatible with the latest SDK. Haven’t had time to do this yet, but we fully intend to continue support of Canon and Nikon.
Thanks Ken! I will wait for that and stop looking for a workaround.
Any update on the latest Canon SDK support for supporting the 5D markIV?
I’m new to SGP so may be doing something wrong but I’m getting this message with a 5d Mark IV also. The camera is in manual mode and it looks like it ought to work, but I’m getting the EDS_ERR_NOT_SUPPORTED also. Any ideas on what I should do or is this really not a supported camera?
Ken announced a new version of SGP for the end of October that supports the new Canon SDK and which the new Canon Cameras should work with.
Thanks for that info! I’ll put things on hold until that comes out.
Thanks for the new update of 2.6.0.24. However I still encounter the same error with Canon 5D4.
