dts350z
December 28, 2014, 6:40pm
1
Using the mainsequencsoftware.com installation, Windows asks if the installation installed correctly, when I click done.
Then, in SGP I get:
[12/27/2014 7:21:24 PM] [DEBUG] [Telescope Thread] ElbrusHelper: Calling analyze…
[12/27/2014 7:21:25 PM] [DEBUG] [Telescope Thread] ElbrusHelper: Analyze finished…
[12/27/2014 7:21:25 PM] [DEBUG] [Telescope Thread] ElbrusHelper: Plate solve failed.
[12/27/2014 7:21:25 PM] [DEBUG] [Telescope Thread] ElbrusHelper: Creating Elbrus object…
[12/27/2014 7:21:25 PM] [DEBUG] [Telescope Thread] Killing last instance of Elbrus…
[12/27/2014 7:21:25 PM] [DEBUG] [Telescope Thread] Elbrus Failed to plate solve: Retrieving the COM class factory for component with CLSID {EC34FFB3-39DD-4585-B6B8-1900ED7E7687} failed due to the following error: 80080005 Server execution failed (Exception from HRESULT: 0x80080005 (CO_E_SERVER_EXEC_FAILURE)).
I’m using the 2.4 beta version of SGP, to get iso12800 with my Canon t3i.
dts350z
December 28, 2014, 7:09pm
2
Elbrus seems to run OK by itself. Although I can’t get it to solve anything:
“Position Not Found”
Am I supposed to manually start Elbrus for use with SGP?
Ken
December 28, 2014, 7:39pm
3
No SGPro will start it for you. Did you run the Elbrus installer Admin? Your error means that the Elbrus COM Server was not registered with the OS during install.
dts350z
December 29, 2014, 3:50am
4
Yes I ran it as admin.
Can I register it on the command line?
Ken
December 29, 2014, 4:15am
5
You can give it a shot. Open a “cmd” window as admin , then navigate to the directory you installed Elbrus in. When you are there, run:
Elbrus.exe /regserver
dts350z
December 29, 2014, 5:04am
6
I did that with no error or result on the command line.
Now when I try to solve with Elbrus I get two errors:
One about canonRaw.tmp being used by another process and one about Elbrus failing with a CO_E_SERVER_EXEC_FAILURE).
If I switch to astrometry.net , solving works.
