End Of Sequence At Start v1660
A few minutes after starting SGP, a message popped up saying it was not safe to start so it was running the end of sequence options. SGP was just sitting there, “run sequence” was not clicked. I had connected and looked at the safety monitor, then disconnected. The message appeared sometime later. The status box did say that end of sequence options were run. Log is at:
Can you clarify this report here? Is the issue that the safety monitor was rereporting safe and shut down anyhow or maybe that there was no safety monitor connected as all or something else?
Do you have Restart on SAFE enabled? If so, SGPro was likely waiting a safe signal and then would restart after 5 minutes.
Can you clarify this as well? You did this before the sequence started or maybe when SGPro was just waiting?
This is normal for shutdown on unsafe.
Every time I bring up SGP, connect the safety monitor (which is unsafe), I get this after a couple of seconds. The status shows gray, then red initially. I found that if I connect it again, it stays connected and red. So no biggie, I guess. Just surprising when I hadn’t done anything other than connect the monitor.
Ya, this is a thing on our list. It seems like it’s operating as intended by your description, it’s just that “intended” in this case falls a bit short. By popular demand, the unsafe shutdown operates out of sequence in order to protect gear from the elements in the case that the sequence is finishes or has not yet started. In other words, we need to differentiate this initially unwanted signal from a real signal.
In your case, what causes the monitor to report safe? For example: observatory shutter opening, etc.
