Hello
I had some problem in centering the target after the flip.
So, as suggested in some topics here, I removed all the stars in the model, letting sgp to build it’s own model.
Sgp was able to center with no problem and I found 3 new stars in the eqmod interface, coming from the point & center phase.
While SGP was taking frames, I decided to remove such stars, so that a clean model could be available when flipping.
Result: after the meridian flip, the telescope was pointing the floor.
In order to recover, I had to disconnect and restart the mount, returning in home and restart the sequence.
I’m a little bit confused about the situation. Of course, next time I will not delete any star from the model.
Why the mount decided to point the floor ?
Is there anything else that I should check ?
Thank you
Francesco
