Trying to connect all the equipment - Telescope (Gemini 2), SBIG camera, Focuser - selecting each of the "connect icons’ prompts the configuration setup(s). NOTHING will connect. SBIG connects just fine using Maxim. Mount and camera connect using SkyX. Focuser (Focuser Boss) pops up set for the hub. trying to connect the mount pops up the ASCOM driver and then disconnects the scope on exit. Worked last time - about 3 weeks ago. Uninstalled 3 and installed 2 - same results. Changed out usb hub - no resolution.
All the profiles will not connect to anything. What’s up?
oohh, I didn’t expect that! Did you imply in your earlier post that you re-installed ASCOM? Admin Privileges … I just upgraded from Win7 to Win 10 and I had to disable all my admin privileges on all the applications before it would connect to the mount.
I think it is log file time and ask for developer help.
