The log states that the driver couldn’t find a telescope on Com1. Might need to set the correct com port in the driver settings. Also make sure you’re running both applications at the same level. For example, make sure you don’t have one running as administrator and the other running normally.
Here’s an updated.
After about an hour if getting it to work on com2, the error came back. What I didn’t notice the first time it appeared is that there was an error being displayed on my hand controller. It was the dreaded “no response 16/17” errors. This error is known to signify the death of the motor controller board on the Celestron AVX mount. The motor board will have to be replaced.
