I used the Beta version 3.1.0.198 successfully for a few days about a week ago. It is clear out there again finally tonight and when I double clicked my sequence to open the app and the sequence file it threw the error: “Error in ReflectDataModel: value cannot be null”. It was on the start up splash screen in the ‘Creating default sequence…’ step when this happened. I tried opening the app through the main icon rather than a sequence file, but the same thing happened. I have resorted to reinstalling 3.1.0.153 and the app is working properly again. Here is the log file:
Thank you for looking into this. Weird that you can’t replicate the issue. I have just reinstalled 3.1.0.198 and it opened successfully to begin with. I could even open the .bak file after changing its extension as you suggested - thank you. However, very quickly it started throwing the same error as detailed above. Possibly after doing a save - I’m not entirely sure. Anyway, I’ve installed 3.1.0.170 and all works perfectly again, so I definitely have an issue with 3.1.0.198…
I have put the .bak file and all the log files from this morning here:
