Error message when trying to open Equipment profile
When attempting to open my default equipment profile via the Equipment Manager the following error message is displayed. Using the help documentation, it’s not apparent what the message is trying to tell me and thus problem actually is. I am able to use this profile in both versions 3 and 4 of SGPro, and it appears to operate as expected. I’m able to also open any of the other profiles.
“Error opening profile (QSI at f7): An item with the same key has already been added.”
Clearly I’ve missed the obvious somewhere.
Link to Logs
Useful Info
OS: Microsoft Windows 10 Pro
Ver: 4.5.0.1631 (64-bit)
.NET: 4.8
ASCOM: 6.6.1.3673
Likely you did not. There are several migrations required for use of 4.5 and this is likely just a missed one. Do you think you might be able to share the actual broken profile itself?
Here is the profile
QSI at f7.sgp (26.0 KB)
The only things that I can think of is that having updated to this version I had to redo the filename format that I usually use. Could this be the issue?
Thanks. This should fix it here:
Sequence Generator Pro 4.5.0.1636 is Released for General Use - Releases - Main Sequence Software
Many thanks Ken, this did the trick.
