This is a slightly wierd one! I was trying an imaging run on NGC 5139 again
- 10 x 2 min Luminance shots at 0 gain
- 10x 2 min Luminance shots at 100 gain
- 10x 2 min Red shots at 240 gain
- 10x 2 min Blue shots at 240 gain
- 10x 2 min Green shots at 240 gain
The red green and blue shots all worked fine and each has the filter name embedded in the light frame name; the Luminance shots don’t have Luminance in the light frame name and several seem to be missing or named Ha???
The PC crashed a bit later - so I will try again and watch notifications carefully (I had to remove an old 1TB drive that was unused but likely just about to die and casuing 100% disk access and clogging up Windows 10 - after its removal everything flew).
So I don’t know if this behaviour is a bug (missing file name) or a Luminance filter change fail and I missed a whole lot of alerts (I didn’t see any) or some other issue. As of now I have no idea how I got Ha shots from a Luminance run? Nor why the Luminance frames don’t have Luminance in the name?
Any ideas?
Thanks, Matt
O/S Windows 10 PRO
SGP - latest 64 bit release
