I am having some diffuculty getting my exposures correct. I think…
In Sharpcap I expose on an image fit let’s say 1 minute. My gain is 350. And my image is recorded well.
Than I go over to SGP and try the sane thing. Same exposure. Same gain etc. And I get nothing. Just a black screen. So I increase Mt exposure to 20 minutes and I still get a black/blank screen. All with sane gain of e50.
maybe turn on the automatic histogram (screen) stretch in SGP? a properly exposed astro image from any camera is going to look black when viewed without any kind of strech.
Wow. I hope that is the solution. But I do the stretch anyways. I think. I right click the image and select stretch there. Maybe not the same as what you suggest . But I will try your way next time out.
What are the settings that need to be in place to get images to appear in the screen when you select Frame and Focus? Some seem to appear ok. Others never. I have the gain setting at 350 in the camera area. But there must be something else?
Of course after each attempt to get a look at where the scope is pointing I use Stetch to see what might be there. In the cases where all I get is a black screen, stretch does nothing. And if I go with the same exposures used in Frame and Focus and use it in a sequence setting. That function also produces no images. Nothing…
Now - there is a time now and than that frame and focuse does work. Maybe only when I use a quick exposure> Like 3 secs or something. I don’t know.
The bottom line though, if I want to see what the scope is looking at , I can’t use SGP at all . I must go to another application and I go to Sharp-cap. And Immediately up comes the image I am looking for and I adjust what I need to adjust and than back to SGP and run a test exposure and finally begin my work. Lots of extra work when I am sure that doesn’t have to be done.
Also I don’t belieave there is anything wrong with SGP but rather with me not putting in the right settup numbers. But I have no idea what they could be NOW. All worked out. I am at a loss and sorry that this portion of SGP is working this way.
well… ok. does sharpcap connect directly to the camera or thru an ascom driver? does SGP connect thru an ascom driver?
sounds like the data coming from the camera is sometimes completely 0’d out for some reason. i don’t have any experience with these cmos cameras so i’m not sure if what you are looking at is a symptom of bad drivers, or just interoperability bugs (because these cameras are relatively new.)
i think you should post some SGP logs to see if jared or ken can see anything there that looks wrong.
